EICO HF-81 with GR Research Speakers
0 Members and 1 Guest are viewing this topic. Read 1530 times.
dknywinnie
  • Music for Life
« on: 6 Apr 2012, 04:42 pm »
I've got a EICO HF-81 int. Amp and would like to connect it to a pair of GR speakers. Which speaker model will be the best match for the system?
LarryB
Re: EICO HF-81 with GR Research Speakers
« Reply #1 on: 6 Apr 2012, 07:53 pm »
"Voicing" aside, the fact that the amp puts out only about 15W means that it would be a better match for one of the higher-efficiency speakers.
Have you seen this review?
LB
HT cOz
« Reply #2 on: 6 Apr 2012, 08:27 pm »
I agree with LB something with high efficiency like the 12" V series. If you're not into OB there was one member who built them into cabinets.
S Clark
« Reply #3 on: 6 Apr 2012, 08:28 pm »
I can speak from experience on this topic.  I've matched a pair of Eico HF-12s, the mono equivilent of the 81 with the AV3's, the AV1's, and the Neo2x.  It provides all you could possible want on the first two, and covers 95+% of your power need with the latter.  They are very nice little amps and will power anything that Danny makes outside of the LS series.
