0 Members and 1 Guest are viewing this topic. Read 4625 times.
One thing you might be able to do, depending on the design of your arm, that wouldn't be visible from the front is to blue tack a giant washer onto the back of your counterweight. The armtube would fit inside the hole of the washer and that should be plenty of weight to compensate for the heavy cart.
Seems like that would change the resonant frequency considerably?
