Other Stuff
Archived Manufacturer Circles
ModWright Instruments (MWI)
dario miniwatt 70 GZ32 and the 36.5 preamp
0 Members and 1 Guest are viewing this topic. Read 1573 times.
stump4545
5 Apr 2012, 02:25 pm »
when i try to use my "dario miniwatt 70 GZ32" rectifer it keep blowing out my fuse in the preamp.
can i use this tube and/or should i just change my fuse in the 36.5 to a bigger fuse?
thanks for the help
rpf
Re: dario miniwatt 70 GZ32 and the 36.5 preamp
5 Apr 2012, 11:15 pm »
I didn't have a problem with using a GZ32 in the 36.5 but I also didn't do it for too long preferring a 5AR4 in the pre-amp and, alternately, a GZ32 and a High Wycomb GZ37 in a Modwright Sony 9100ES.
stump4545
Reply #2 on:
6 Apr 2012, 02:18 pm »
if the changing of a rectifier tubes blows the fuse in the 36.5 what does this signify?
need a bigger fuse, tube not compatible, or rectifier defective??
thanks again
rpf
Reply #3 on:
6 Apr 2012, 02:35 pm »
Don't know. Email Dan.
modwright
Industry Contributor
Reply #4 on:
16 Apr 2012, 04:34 pm »
I have tried these also and my experience was the same . Bottom line, not a good match. Have not looked at the data sheet, but my guess is that our PS is not designed for this specific tube.
Dan
Other Stuff
