rectifer tubes turns neon blue on startup
0 Members and 1 Guest are viewing this topic. Read 1955 times.
stump4545
« on: 5 Apr 2012, 02:22 pm »
is it time to change my recitfer tube on my preamp for sure?
Re: rectifer tubes turns neon blue on startup
« Reply #1 on: 5 Apr 2012, 04:13 pm »
Purple is definitely yes. Blue, if around the materials maybe due to cobalt impurities and no problem. I would assume the rectifier is new.
Cheers.
Wayner
« Reply #2 on: 6 Apr 2012, 12:10 pm »
I  believe the color is also from impurities in the plasma stream within the tube. I had an old Dynaco Stereo 70 amp that exhibited glowing blue tubes near end of life. I'd keep running it until I get other signs of tube failure.
Wayner
stump4545
« Reply #3 on: 6 Apr 2012, 02:19 pm »
should i ever be concerned that the rectifier blows up! or does anything dangerous?
thanks for the help.
Quiet Earth
« Reply #4 on: 6 Apr 2012, 03:13 pm »
Which rectifier are you using? (what number designation, like 6X5, or 5u4?)
Is the blue glow only on the inside of the glass, like a blue frost? Or is it a bright blue light comming from within the tube?
How long has it been since you replaced the rectifier?
stump4545
« Reply #5 on: 6 Apr 2012, 03:26 pm »
i was using a  mullard F32B1D1 that i have had for about 2 years so i think it is about time to change but wasn't sure if the blue neon light is a normal warning to change.
thanks a lot.
Quiet Earth
« Reply #6 on: 8 Apr 2012, 12:13 am »
Sorry for the late reply. Is that number actually the rectifier part number or is it a Mullard date code? Just curious . . . .
If it were me I would probably get a new rectifier anyway just see if there is a change/difference/improvement. If there is no change then you have a spare tube,,, which is always a good thing.  :D
ltr317
« Reply #7 on: 8 Apr 2012, 02:54 am »
F32 is the type of tube.  I don't have the Mullard list so not sure which type of rectifier.  B1D1 = Blackburn factory, 1961 or 1971, manufactured in the first week of April.
