0 Members and 1 Guest are viewing this topic. Read 10904 times.
Hi Guys, I decided to take off my woofer drivers to get a look inside the cabinet and was wondering if anyone had a suggestion as to how tight I should tighten the screws when I put the drivers back in place. I screwed them in snugly and was careful not to overtighten but I'm not sure if there is a good rule of thumb regarding how snug you should tighten the screws. Also, it seemed they were not particularly tight when I unscrewed them. How tight do you screw in your woofer screws? Thanks!Jack
