SOLD! Sophia EL34 Integrated tube amp / 28wpc / $445
0 Members and 1 Guest are viewing this topic. Read 2614 times.
ludimagis
SOLD!
For Sale is a wonderful integrated push pull amp by Sophia.(Not to be confused with the popular Sophia S.E.T. Music Baby Amp (10w/ch).)
This was an earlier version that retailed for $1495.($1625 with the upgraded caps & better EL-34 tubes.) It is a 2 rca inputs, tube, push pull intgrated, that is rated at 28w/ch. It is approximately 7 years old & I am the 2nd owner. It was originally made with upgraded Mundorf Supreme signal coupling capaciors. I have had some pretty good amps pass though my system in the past 10 years (Ayre, VAC, Rogue) and this Sophia has remained. It has never been my main amp, maybe getting 1-2 month of playing time each year in a secondary setup. It is just such an enjoyable amp, very musical, leaning to the warm side of neutral but with enough detail that I wouldn’t describe it as “tubey”. It uses 4ea EL-34 & 2ea 6U8. It curerently has NOS brown base 70′s Svetlava & NOS 70′s RCA 6U8 tubes. It is functionally 100%. No hums, buzzes, or pops. It was on the bench about a year ago to have the selector switch replaced and all internal checked. My tech put in a higher quality switch, but it is 5 notch (Only 2 are required - it functions perfect). There are a couple of smal dings on the bottom of the front wood panel, but it is absolutely presentable.
“S.E.T.” stands for Sophia Electric Technology
7Hz-30KHz +/-3dB
Power:28 watts x 2 in Push and Pull circuit design
Inputs:Two sets of RCA inputs. Relay switches are being used for shortest circuit path.
Output tubes:El-34 x 4 Input/Driver tubes:One 6U8 per channel Frequency:7Hz-30KHz +/-3dB
Signal/Noise Ratio:-90dB Distortion:less than 1% at 10 watts power Hum:2mv Weight:32 pounds
Dimension:Width: 11 inches, Height: 9 inches, and depth (not including binding post and knob): 13 inches
Color:Black metal chassis with hardwood deco
AC Power:120V/60Hz
Buy with complete confidence, 100% feedback for 10+ years.
It will be very securely packed & buyer pays any PP & actual insured ground shipping fee.
send me a PM for pics or take a look at :
http://audioasylumtrader.com/ca/listing/Integrated-Amplifier-Tube/Sophia/S.E.T.-EL-34/Integrated-push-pull-amp/58878
« Last Edit: 4 Apr 2012, 10:51 pm by ludimagis »
saisunil
Re: SOLD! Sophia EL34 Integrated tube amp / 28wpc / $445
« Reply #1 on: 12 Apr 2012, 02:28 am »
Ted was a pleasure to deal with - great transaction ...
Super packing - arrived safely ... minor tube issue was resolved gracefully ...
Back to glowing warmth of tubes that I have been craving for ...
Thanks Ted
Sunil.
ludimagis
« Reply #2 on: 12 Apr 2012, 08:49 pm »
Sunil, Pleased that your initial impressions are positive. That amp is just so easy to listen to. Very much an amp for a music lover that just happens to have an audiophile ear. Hope you enjoy as much as I have!
