Other Stuff
Archived Manufacturer Circles
ModWright Instruments (MWI)
Impedance Matching
Impedance Matching
0 Members and 1 Guest are viewing this topic. Read 1564 times.
dhanson68
Newbie
Impedance Matching
1 Apr 2012, 02:22 am »
I am thinking about pairing a LS 36.5 with a Conrad Johnson MF 2500A amp.
I am a bit unclear about impedance matching.
The output impedance of the LS 36.5 is 110 ohms and the input impedance of the CJ is 100k ohms.
Is this a good match?
Thanks for any help.
ted_b
Volunteer
"we're all bozos on this bus" F.T.
Re: Impedance Matching
3 Apr 2012, 02:17 pm »
10x is the mininum recommendation for impedance matching (for good voltage transfer). You are at around 100x. You are absolutely fine.
roscoeiii
Reply #2 on:
3 Apr 2012, 02:26 pm »
With an output impedance of 100 ohms, you ought to be fine driving any amp with the 36.5, impedance-wise.
Never seen an amp with anything close to 1000 Ohm input impedance.
modwright
Industry Contributor
Reply #3 on:
16 Apr 2012, 04:39 pm »
Most amps do NOT have an input impedance below 10K. 100 x 100 = 10K, so that is the theoretically ideal match. Nothing is set in stone of course, but 1:100 is the theoretical ideal.
Dan
wilsynet
Reply #4 on:
17 Apr 2012, 09:27 pm »
Is there harm in being
over
100x? For example, while 100 ohm output impedance implies an ideal 10K input impedance, is there harm in having a 100K input impedance?
Other Stuff
Impedance Matching
