Combination of Bryston Amps for 7 channels
0 Members and 1 Guest are viewing this topic. Read 2927 times.
ec
« on: 16 May 2004, 11:22 pm »
Folks,
Here is my current setup / situation:
- five TB-2s (incl TB-2C) + two TB-1s for a 7 channel setup
- Bryston 3B SST powering the front L/R, Acurus Five 200 powering the remaining 5 channels
- Bryston SP 1.7
- One of my friends is taking the above mentioned Acurus Amp and another one I have off my hands.  Perfect opportunity for pure Bryston amplification  :mrgreen:
- At some point in the "future" I will be upgrading the TB-2's to some type of full range PMC's
Here are the scenarios I am considering and why.  Your comments and suggestions are most appreciated.
two 4B SSTs + one PowerPac 300 SST
two 4B's would be used for L,R,SL,SR
PP300 used for C
existing 3B for RR, RL
+ should have sufficient power for future speaker upgrades
+ two 4B's provide the flexibility to biamp for the future
+ provides lots of placement flexibility
- expensive scenario
two 4B SSTs + one 3B SST
new 3B used for C in either bridged mode or biamp
+ two pairs of amps provides most flexibility (placement, bridging, biamping, etc)
- most expensive of all provided scenarios
five PowerPac 120 SSTs
existing 3B for L,R
PP 120's for remaining channels
+ can use very short speaker cables
+ just a little more expensive than a 9B
+ potentially less cross talk than a 9B
- may not provide enough power for future speakers
- proximity to outlets
- 12V trigger in only not in and out like the 3B, 4B which can be daisy chained
- two PP has less flexibility compared to stereo amp (eg bridging and 12V triggers)
two 3B SST's + one PowerPac 120 SST
PP120 used for centre
three 3B's used for remaining channels
+ 3B's can be used for biamping (or bridged mode) for front three speakers in future
- may not provide enough power for future speakers unless more amps purchased (eg bridge existing amps)
- the 4B's are just a little bit more money but twice the power
one 9B SST
existing 3B used for L.R
9B used for all other channels
+ least amount of outlets required
- less flexibility in placement
- three of the 9B channels connected via balanced, last two via RCA.
You are probably wondering why I haven't considered the 6B.  I find that the cost per ch compared to a 4B is much more.  I like the flexibility of having a "monoblock" + stereo amp especially if this can be had at a near equivalent price tag.   Also, cosmetically, the 3B and 4B look similar from the front.  So when the amps are lined up under my screen it will look more balanced.  Why not a 6B in the centre below the screen?  I have one of my subs there.
I would like your opinions on the above and or how you are powering your 7 channels and why you are doing it in this manner.
Eric
Fife
« Reply #1 on: 18 May 2004, 11:37 pm »
I would say for your setup:
2 X 3B SST for rears & surrounds.
1 x 4B SST for FL/FR
1 X PowerPac 300 SST for centre
I would prefer a 6B up front but otherwise that would be my opinion for the front 3 channels.
I have my 6B off to the side as I have no room up front.
Of course you could dump the 3B's for your rear and just get 4B ST's.
So many options......decisions decisions...
 :lol:
ec
« Reply #2 on: 19 May 2004, 10:45 pm »
Fife,
Thanks for the reply.  My decision has been made less expensive recently as a friend may be selling his 4B SST.  When (not if  :D ) this happens, I will probably go with my first or second scenario in light of recent events.
jethro
« Reply #3 on: 19 May 2004, 11:22 pm »
Eric,
If you go for combo #1, just remember that PMC is no longer putting the threaded inserts in their speakers.
