0 Members and 1 Guest are viewing this topic. Read 7352 times.
Biggest fear is blowing the tweeter. Not the replacement cost but the installing of a new one. How difficult is it? Soldering involved? A big pain the a$$?
Well the OP question is kinda mute for me now because I've removed the fuses in my MMG's. Obviously these are QRs not TRs like the OP's, but for what it's worth I didn't blow any fuses before I removed them either, using SS amplification. Sound quality was much improved by removing the fuses from the circuit. I would note that none of the other 5 pairs of speakers in the house came with fuses and the one speaker I blew up took out both woofer and tweeter.
Whereas according to Wendell Diller, the fuses are sized to give the tweeters complete protection in torture tests.
I saw a photo of a diaphragm that had wrinkled, apparently what happens with planars is that when they heat up, the metal and plastic expand at different rates and eventually they go their merry way and you get delam and wrinkling.
Do you think I would still hear music (hi freq) with a blown tweeter?
I inherited a pair of MMG with one panel looks exactly like you described - the tweeter strips of one panel were wrinkled looking thru its sock.I didn't know/think the tweeter was blown because I could still hear the high freq coming out when playing music. I threw them into storage because the panel with wrinkled tweeter sounded softer than the other side and didn't have time to investigate yet.Do you think I would still hear music (hi freq) with a blown tweeter?
Wrinkling of the wires is sometimes normal and can come that way from the factory. When I bought my 1.6's I noticed that the wires had some wrinkling. I brought them back to the Magnepan factory as I live 20 min away and they said that can be normal and that they try to pair those speakers with white sock coverings so it is not as noticeable. They gave me a new pair by the way and they sounded no different. Does the speaker buzz at all? It it does then the wires need to be re-glued and you can buy the glue from Magnepan.
I've seen that wrinkling. The problem I'm referring to is wrinkling of the Mylar diaphragm due to thermal damage. That's a different story (unless I suppose it's very minor).
