0 Members and 1 Guest are viewing this topic. Read 8216 times.
How do I clear or reset the Plays count?
srb - the Reset Play Count only appears on songs in playlists. It's not on the menu for radio streams but it did appear when I right clicked on a song.
Wow, that is so awesome! I've been missing my WIP sports talk station from Philly ever since I moved away, and it's there on the default list...WOOHOO!!!! Thanks Steve!
Hint. If you put the call letters and the words listen live into Google it will usually return the a link to a radio station's stream. Works great for stations that are not in itunes.
I may have to try that one as I often listen to KUWL-FM, but iTunes only gives you their 128K stream. They have a 256K stream but can't get iTunes to play it- I have tried pasting in the URL under 'open stream' to no avail.
Is this the URL you are trying to play?http://wprhqstream4.uwyo.edu:8000/kuwl256.mp3Steve
