Powered sub for 626R's?
0 Members and 1 Guest are viewing this topic. Read 1494 times.
jasonc
« on: 16 May 2004, 03:13 pm »
What sub are you currently using with your 626R's other than VMPS?  I'm looking for a nice plug and play sub that will work well w/the 626 monitors.
Can't fund a seperate amp etc. if I were to go with the VMPS Larger.
Any rec's would be appreciated.
Thanks.
pjchappy
« Reply #1 on: 16 May 2004, 05:30 pm »
How much are you looking to spend?
Maybe check for a used Larger Sub. . .I see them pop up every once in awhile.
p
doug s.
  • makin' music
« Reply #2 on: 16 May 2004, 08:31 pm »
as many here know, i am all for vmps subs - i firmly believe that it would be hard to match their performance w/powered subs, even after the cost of active x-over, amps, & wire are factored in.
that said, i needed a cheap sub fix for a second system based around the proac tablette 8 reference signatures.   constant searching of ebay & classifieds allowed me to nab two yamaha yst-sw305's for ~$350 shipped.  these now-discontinued subs have a pair of servo-driven forward-firing 7" woofers powered by a 200w amp.
using one was ok, but i was sure glad when i finally found the second one, about a month later.  good subwoofin' requires stereo subs!   :wink:   do these compete w/a pair of vmps larger subs?  no, but they are quite respectable, providing clean, tuneful bass, & are able to energize the ~15x22x8 room i have them in...  and, at ~23.5" tall, w/a narrow front, they'd make a decent stand for the 626r's.
yamaha has replaced these with yst-sw315's, which usually go on ebay (new) for ~$190-$200, plus shipping.  but, these are a different design, w/one 10" downfiring driver.  i don't know anything about their performance.  and, also - i know audiojerry likes his yst-sw205's which are like mine, but w/only one 7" driver, and a smaller amp.  his recommendation, among others, was what made me search out the yst-sw305's...
doug s.
rosconey
« Reply #3 on: 16 May 2004, 08:43 pm »
what about diy-
2 of the parts express 10" dayton 99$ subs
a used any size vmps off agon
