0 Members and 1 Guest are viewing this topic. Read 9543 times.
I'm just wondering - is this thread posted in the right circle? Perhaps Enclosures would be a better bet...
To answer the subject directly: ACTIVEThe advantages of truly active designs (one amp connected directly to each driver) are significant and many. Primary are improved dynamics, ruler flat frequency response, and incredibly deep bass. The biggest disadvantages are: nearly impossible to find a tubed active speaker and it takes away the audiophile "fun" of hunting for the perfect synergistic amp/speaker match.Of course by definition single driver designs are active. Helper tweeters "ruin" it , but powered subwoofers are OK. And watch out for powered speakers that use one amp for multiple speakers (placing the crossover between amp and drivers). That's just a passive speaker with a matched power amp attached.
have you personally compared poweramp+passive vs active ?i know that active speakers are more efficient circuit systemsbut iv read that its expensive because its a new technologyso i heard some people saying like, for the same money you can spend, poweramp+passive combination sounds better than active speakers do you think they are wrong?
Another point - when well done, an active system should be cheaper than passive for a given level of performance. Presuming we are talking about amplifiers built into the speakers, the amplifier case and speaker wires are eliminated, at least as expensive separate components. In an amplifier the case and knobs cost as much as all the rest of the components.
i have benchmark dac1currently using er4s via headphone out of dac1but im trying to get a speaker systemmy budge: a few thousand dollars for used gearsim thinking mc275 + a pair of b&w bookshelf speakersor a pair of active system of around 2/3 cost of the above combinationmaybe a pair of focal twin6 be ?which would sound better?
Better ? No different , yes. Only you can determine "better". J. Personal taste being the main focus. Then room, ancillary gear and so on. Just too many factors involved. You must try yourself. Opinions are just that. There are several speakers available that are self powered today. Just give them a listen.charles
Not that we must or should match what the professionals do, but they almost universally use active designs in the recording studio. Their primary concern is results (fidelity). Years ago did A/B audition between Paradigm Studio 20 ($800/pair smaller 2-way standmounts) versus Paradigm Active 20 ($1600/pair, biamped version of the Studio 20). No comparison; dynamics, flat response, unbelievable bass. They sounded better all the way around than the Paradigm Studio 80 ($1600/pair floorstanders). In active designs each amp directly "sees" the simplier driver load versus squeezing through the inefficient electronic maze called a crossover. Those built by the pros for the pros are normally, properly matched/sorted out. Note that bi-amped passive speakers are not the same as active designs.
