Record Lamp: Halogen or LED?
0 Members and 1 Guest are viewing this topic. Read 4344 times.
orthobiz
« on: 18 Mar 2012, 04:21 pm »
Typical vinylhead question...Audio Advisor has a reduced price on the Littlite 18" Halogen lamp but they also sell an LED lamp from the same manufacturer. Both have dimmers (bad for sound systems, no?).
Would probably turn the light off when not cueing up a record, but are there important differences between the two types of bulb?
Paul
Scott F.
Re: Record Lamp: Halogen or LED?
« Reply #1 on: 18 Mar 2012, 07:52 pm »
If you use a strobe disc to set your speed, you'll need to use a halogen bulb (IIRC). The strobe relies on the 60hz pulse in order to be visible to the eye. I don't think it shows up with an LED. I could be wrong though.
roscoeiii
« Reply #2 on: 18 Mar 2012, 08:08 pm »
All of the prices for a record lamp seem mighty high on Audio Advisor. I would imagine a much cheaper alternative would be not too hard to find. Maybe something battery powered?
JakeJ
« Reply #3 on: 18 Mar 2012, 08:31 pm »
The halogen might be a warmer color but the LED version has the advantage of not needing bulb replacements.  I don't think the dimmer will be a noise issue due to the low power of these lights.  If it is you'll know it immediately from the audible buzz coming from your speakers.  :o
Scott F.,
You are thinking of a light source to check the table's speed accuracy.  That would be a fluorescent bulb, I use a small automotive drop light with my strobe reference disc.  :thumb:
Æ
« Reply #4 on: 18 Mar 2012, 08:58 pm »
Scott F.,
Turntables that have a ready built in light for strobe - speed adjustment, use a neon bulb.
The typical dimmer, for whatever incandescent bulb, creates a lot of noise on the AC line unless it is heavily filtered.
Since an LED runs off of DC, I would think that any dimmer for an LED would already be isolated from the AC line. Hopefully no dimmer noise back on the AC line with an LED light.
eclein
« Reply #5 on: 18 Mar 2012, 09:26 pm »
Paul I was checking them out after I saw your thread and I would get the LED one only because you can pick a couple colors of light and it has the base.
I have no other reason-the red light might be cool
orthobiz
« Reply #6 on: 18 Mar 2012, 10:26 pm »
Thanks for the replies. Anybody have a favorite "DJ" style lamp they use, something I can source myself? And BTW, would not use it to speed check with a strobe.
Paul
Photon46
« Reply #7 on: 18 Mar 2012, 10:43 pm »
Something like this inexpensive Ikea led task light would fill the bill nicely: http://www.ikea.com/us/en/catalog/products/70180955/
TomS
« Reply #8 on: 18 Mar 2012, 11:41 pm »
I use this IKEA Jansko and it works great. Nice heavy base and long flex neck. http://www.ikea.com/us/en/catalog/products/20169658/
DaveyW
« Reply #9 on: 19 Mar 2012, 12:08 pm »
I'm using the clip on version of this lamp for my vinyl inspection rig
Very effective  :thumb:
Plenty of light and it doesn't get too hot
TomS desk lamp version looks a lot neater though  8)
Minn Mark
« Reply #10 on: 19 Mar 2012, 03:31 pm »
I would dbk-ck with audio advisor. When I bought my littlite, I opted for the halogen as I wanted a dimmer. For the LED, one gets an on-off switch. I'm not sure they offer a dimmer for LEDs.
M
Wayner
« Reply #11 on: 19 Mar 2012, 03:35 pm »
The LED version offers a choice of white, red or white+red LEDs, so I'm guessing there is a 3-way switch in the base.
Wayner
roscoeiii
« Reply #12 on: 19 Mar 2012, 03:38 pm »
Lot of battery powered LED lights available out there. Maybe I finally have a way to try out the benefits of a battery-powered component in my system :thumb:
Wayner
« Reply #13 on: 19 Mar 2012, 03:42 pm »
A good point with battery use....are the wall warts supplied by the Littlelite going to cause a buzz in your system? There is a transformer in there afterall, and with only 6 feet of cord, could be a concern?
Wayner
orthobiz
« Reply #14 on: 19 Mar 2012, 09:03 pm »
Thanks, Davey, it's here (in the US)
http://www.ikea.com/us/en/catalog/products/80169636/
Does it have a wall-wart?
Paul
DaveyW
« Reply #15 on: 19 Mar 2012, 09:28 pm »
Paul
Yep! A compact 3W version - am sure it'd be a similar thing over the pond.
decal
« Reply #16 on: 19 Mar 2012, 10:48 pm »
This is the one I use. It makes no noise at all in my system. Go to Littlelite for info.
« Reply #17 on: 19 Mar 2012, 10:52 pm »
Hi Paul this a battery powered LED light mounted to my ceiling. I think I paid around $7 for it.
It has a high & low setting. Sorry for the terrible pic.............Bill
« Reply #18 on: 19 Mar 2012, 10:53 pm »
It has a high & low setting. Sorry for the terrible pic.Needless to say I have a low ceiling............Bill
