Well Tempered Lab Amadeus Dimensions
0 Members and 1 Guest are viewing this topic. Read 3204 times.
lesmarshall
« on: 17 Mar 2012, 05:17 pm »
 Hello,  this is my first post to the forum. I am considering an Amadeus and need to know if it will fit in my available space. I have not been able to find its dimensions on any website. Does anyone know the exact dimension of the Amadeus? Also , in addition to the overall depth ,  I am looking for the measurement between the front and back feet. Thanks for your help.
jsawyer09
Re: Well Tempered Lab Amadeus Dimensions
« Reply #1 on: 18 Mar 2012, 04:56 pm »
Hello.
Mine is 19" (w) x 16-1/4" (d).
The furthest foot in back to the front is about 14" center-to-center; the other two are configured a little differently, as one is a bit further in that the usual four corners-type. Hope this helps.
lesmarshall
« Reply #2 on: 18 Mar 2012, 06:59 pm »
Thanks.
roscoeiii
« Reply #3 on: 19 Mar 2012, 01:26 pm »
If the WTA is too big a footprint for you, I just read on a thread here about the Simplex that it has a smaller footprint.
