Bryston SP1.7 Guidance
0 Members and 1 Guest are viewing this topic. Read 2811 times.
Woofer
« on: 17 Mar 2012, 05:14 pm »
Hello-
Next week I’ll be taking delivery of a pristine SP1.7.  I’ve searched for and read what I could find but I still have a few questions regarding the SP2 upgrade.  I should add that I’ll be using the SP1.7 for 2ch listening only.  Also, I’ve come across a link to a PDF on the  Bryston site but the file no longer exists there – if someone has it and could either post it or send it to me I would really appreciate it.
•   Can someone tell me what exactly is replaced in the upgrade and, since I’m daft about circuits, why and to what benefits?
•   Does the upgrade have any downside (feature and/or sonic losses)?
•   I won’t know what software is loaded in unit until I receive it, can someone tell me the latest SP1.7 version(s)?
$1,500 USD is more than I paid for the unit and a lot of money to me, so while I’m open to saving the cash for a future upgrade, I just want to be sure it’s money well spent.
Thanks for your time and help.
Chris
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston SP1.7 Guidance
« Reply #1 on: 17 Mar 2012, 06:07 pm »
Hello-
Chris
Hi Chris,
If you are using the 1.7 for analog 2-channel only the upgrade is not necessary.  It is only the digital board that gets the upgrade. The upgrade is around $1500 but check with Mike Pickett on that - [email protected].
Also check with Mike on the software but again if only using for analog 2 channel listening no need to be concerned.
james
Woofer
« Reply #2 on: 17 Mar 2012, 06:58 pm »
Thanks for the quick reply James.  I see now I left out some critical information (swing-n-a-miss!).
I've two sources for 2ch... an Oppo BDP-95 and primarily a Mac Mini.  Both feed into a BDA-1... the Mini via Toslink to Opical Mini Plug and the BDP-95 via S/PDIF.  Vinyl has exited the Man Cave, via Stage Left.  So, the DAC portion of either the SP1.7/SP2 I should have beat.  I'm guessing the Bypass Mode is the best for 2ch, so does any of this change your diagnosis Doc?
« Reply #3 on: 17 Mar 2012, 07:03 pm »
If you are using the BDA then bypass is best and it is the same on the SP1 and the SP2.
James
Woofer
« Reply #4 on: 17 Mar 2012, 07:22 pm »
Excellent news - thank you sir!
