Sharp SD SG11 vs Panasonic 25/45/50
0 Members and 1 Guest are viewing this topic. Read 2359 times.
eastein
« on: 15 May 2004, 05:01 pm »
If anyone has had the opportunity to compare the Sharp SD SG11 or similar to the Panasonic 25/45/50 could you please share your thoughts?
PhilNYC
« Reply #1 on: 15 May 2004, 10:33 pm »
I've not heard a stock Panny yet, but my initial thought is that the difference in power (Sharp SD-SG11 is 25watts into 4ohms...Panny's are 100wpc into 8ohms?) would make this an unfair comparison.
I would definitely be interested in hearing someone's opinions on Sharp 1-bit vs. Panny on comparable models...
mca
« Reply #2 on: 16 May 2004, 03:17 am »
I have not heard the Panny but I own the Sharp and think it sounds very good for the price. It also seems much more powerfull than it's 25 watt rating. Drives my 87db sensitivity Ushers with no problem  :D
BenF
  • Guest
I have both the Sharp SD SG11 and Panasonic XR45
« Reply #3 on: 18 May 2004, 04:56 pm »
I am using both of these with identical pairs of Polk RTi28s, the speakers Dennis Murphy recommends redoing the crossover. I haven't gotten around to redoing the crossovers yet.
To put the conclusion first, I definitely prefer the Panasonic XR45.
The SD-SG11 changed rapidly during the first 30-60 minutes it was powered on and got better and better, but no real change I can detect after that. The bass is very tight and the sound is clear and detailed, compared to my old SS stuff. Based on that experience I got another one. One went to a bedroom and the other to the living room. It is a great all in one system, has minidisc and CD, and the build quality is excellent.
For our main listening room, however, I chose to get an XR45. I installed it and it sounded OK, not as good as the Sharp. I was disappointed, but knew from reading the posts that the Panasonic took a long time to be its best. This is completely true. I ran it all the time in party mode and after about 30 days it was way better than the Sharp. The sound is smoother, the imaging better, and I like it better. Unfortunately, something went wrong on one of the boards about 2 months in, since the right channel was down about 1.5 db from the left and I couldn't get it to balance right. Panasonic put in a new board under warranty in just 3 days(!), so unfortunately it is back to the original sound right now and burning in again. It is tough to wait for it to sound better. The tuner is better than the Sharp also, if that matters to you (it does to me).
If more details are needed, I'd have to do an extended comparison looking for what you are interested in. Unfortunately, I've been too busy to listen much at all. My family gets to more than I!
By the way, the Sony all-in-one first generation I tried was much worse than these two. I also like the budget buy both of these were: the Sharps for around $150 and the XR45 for $245 refurbished in black. You can probably tell that I'm going for budget quality sound and this is the best I could come up with given available components at this time.
Hope this is of some help.
Ben
viggen
« Reply #4 on: 18 May 2004, 08:26 pm »
I have the Sharp and the XR10.  The XR10 seems to drive my Carolina JTMs with more ease.  But the Sharp sounds better but doesn't sound as relaxed.  For the record, I used a Wolf Gaincord with the Sharp and stock powercord with the XR10.
eastein
« Reply #5 on: 19 May 2004, 02:38 pm »
I've been using the Sharp in my bedroom and recently tried it in my main system to see how it faired against my gaincard.  There was a relatively dramatic improvement using a Rega 2k as a transport but still no comparison to the gaincard.
Thanks for the replies.
viggen
« Reply #6 on: 19 May 2004, 04:09 pm »
Ditto, no comp to my gaincard either for both the sharp and panny.
