0 Members and 1 Guest are viewing this topic. Read 7184 times.
Wouldn't that be get a higher chair?
Kinda my point.
I suppose it could go either way depending on the original chair height combined with which Maggie, but if you are tilting the speaker back you need a lower chair and if you're tilting the speaker forward you need a higher chair. I think I have this right, but if not it makes no difference, just reverse it. So 1.2's/MMG's you would raise up and/or tilt back with most chairs (or get a lower chair) and 1.7's and up you would tilt forward or get a higher chair (or install a sunken floor).No my boy, you're all confused, the horizon is moving up.
