If you added a sub to the N3, would you change the crossover of the N3 to allow
0 Members and 1 Guest are viewing this topic. Read 1130 times.
Trismos
Danny,
The N3 TL plays pretty low, but if you decided to go with a subwoofer to do the lower octaves, would it make sense to reconfigure the crossover of the N3 so the M-130's aren't trying to play there? If this is the case, what would you recommend?
Thx
Dave
Danny Richie
I let them play full range then add the sub. Just set the settings on the sub to about 35Hz or so and they blend real well.
