0 Members and 1 Guest are viewing this topic. Read 15614 times.
How low the tweeter can cross over, and how much beaming the woofer has at that point.
Hi.Human ear hearing sensitivity is at its maxminum at around 3.4KHz. So best to avoid our ears detecting the dales & hills of the audio response of a loudspeaker in box is to avoid having the X-over point located there. IMO, lower the better as our ears tend to need more power to get same hearing level at lower frequency, plus lower the frequency, less soundwavebeaming our ears can sense.c-J
.. smooth upper roll off of mid/woofer, low fs of tweeter = simpler xo.
Good point about impedance charts, especially if a tube amp is used. And speaker designs are about tradeoffs. So it may be worthwhile to have a more complex crossover in order to achieve a smooth response and lower crossover point (like the 4th order one on the SP Tech/Aether speakers, which is in-phase BTW), or it may be that a higher crossover point is worth it in order to have a simpler first order or series crossover (as seen in some Fritz and Zu speakers, IIRC).
I am not using a waveguide. Again I am looking for theory. Its easy to look up what is paired with what. I am looking personal whys.
A complex crossover my produce a better frequency response, but it isn't better for the impedance. Multiple component (complex) crossovers makes the impedance highly reactive, which is technically worse for a tube amplifier.
