0 Members and 1 Guest are viewing this topic. Read 3349 times.
I have Songtowers with a Songcenter and in-ceiling surrounds for my HT set-up. I don't have a sub. My Audyssey set all three front speakers to Large, but I've noticed that the Songcenter makes a clicky (<-not sure how to best describe it!) sound when the very low bass is sent to the center. The problem goes away when I set the center to Small. Is this the recommended setting? Am I losing anything in doing this given that I don't have a sub? In other words, is the low bass information that was being sent to the center when it was set to Large lost without a sub or does it get re-routed to the L/R's? FYI, I have a Marantz SR7005 AV receiver. Thank you for your help.
Yes, I ran the test tones. The Audyssey run set the Songcenter to Large. I've now changed it to Small and I had the crossover set to 80. As mentioned above, I don't have a sub and the manual suggests the low bass should be re-routed to the fronts. I was still hearing the "clicking" with the Xover at 80. What would the crossover typically be set at for a Songcenter? Thx.
I have the volume at about -2 db or slightly louder when I hear it.
Maybe I misspoke -- the problem is still there (although to a lesser degree) if I set the center to Small. If anyone else has had this problem, please let me know. Otherwise, I'll have to read up more carefully on the settings. In any case, thanks for your thoughts.
