Error 03 startup
0 Members and 1 Guest are viewing this topic. Read 1087 times.
Miroshnikov
Error 03 startup
« on: 10 Mar 2012, 07:56 pm »
Hi! Please help me!
My player startup displays the error is 03 and does not run. Serial number 000 173, firmware 0.97. I live in Russia, but my friend bought me a player in November last year in the United States.
Please, tell me what the error means 03, and I can try to fix it? Maybe you can update firmware?
Sorry for my bad english. I look forward to your help, because I do not know to whom I turn (
Regards, Vyacheslav
  • The Demo is Everything!
    • http://www.bryston.com
Re: Error 03 startup
« Reply #1 on: 10 Mar 2012, 08:15 pm »
Hi! Please help me!
Regards, Vyacheslav
Hi
03 means no analog power supply - may be a fuse blown.  is it a 220 volt/50Hz unit or a 120volt/60Hz unit?
james
Miroshnikov
« Reply #2 on: 11 Mar 2012, 02:28 pm »
Thank you for your help. I replaced the fuse, which burned down and the device back to work.
Regards, Vyacheslav
