0 Members and 1 Guest are viewing this topic. Read 20241 times.
Yep, we will have models for all the SB's, Wadia 170/171i, maybe Simaudio.We may also make AC versions for Bellari, Cambridge, etc. What we need to know are:#1 what products would you like a supply for?#2 what are the power specs/requirements?(voltage, current, AC or DC) #3 what type of input connector is used?Thanks,DustyI would like to see power supplies for the Simaudio Moon 100D and 100LP (both use the same power supply) @18V DC / 0.4A
Do you know the size of the center pin of the connector? Looks to be either 2.1mm or 2.5mmI cannot tell what size it is and there is no specs listed in any of the documentation or on their website...I will contact Simaudio tomorrow.
...and it looks like the current version (110LP) requires 12V DCI think there is a typo in their manual...both the 100D and the 100LP have the same 18V requirement listed on the back of the units and I checked the power supplies (wall warts) for both of my units and they use the same power supply. (18V 0.4A)
I was talking about the current model 110LP (not 100LP).http://www.simaudio.com/moon110LP.htmThe rear photo shows 12V DC, but the owners manual says 18V DC.I have the 110LP and it is 18V, same as the 100D.
Badge,I see all 4 of your posts have your comment contained within another poster's quote. You just need to locate your own comment after the ending {/quote} tag.Steve
That would be great! Let us know...
Any chance you can make them in black, say to match the Touch?
