Wicked great site to learn speaker veenering
0 Members and 1 Guest are viewing this topic. Read 2202 times.
Mark Korda
    • Dawkus
« on: 9 Mar 2012, 09:22 pm »
Hi,check out this site for those who want to veener their speaker cabinets....Mark Korda(http://www.ohio.edu/people/schneidw/audio/veneering.html)
timind
  • permanent vacation
Re: Wicked great site to learn speaker veenering
« Reply #1 on: 18 Mar 2012, 03:47 pm »
That is a great explanation of the process. I considering this for a pair of speakers. If I go that route, this info will help.
Thanks for sharing.
BTW, have you tried it?
doorman
« Reply #2 on: 18 Mar 2012, 04:15 pm »
Have used this method a number of times. Be patient & careful, you will obtain good results!
Don
JoshK
« Reply #3 on: 19 Mar 2012, 03:56 pm »
I use the "iron-on" method too.  Its pretty much the easiest and proven method, especially for beginners like I was.
The other really helpful tip that I learned the hard way was this:
"The router bit may scar the veneer where the bearing rides against it. Use low-tack tape to reduce scarring by the router bearing"
Indeed, don't use the the router bit on the raw veneer itself, it will scar the veneer.  If you mask the veneer off, you will get a thumbnail-like hang over which can be sanded down to flush.  I found I was pretty good with an exacto knife and trimming it down, ymmv.
