0 Members and 1 Guest are viewing this topic. Read 8418 times.
I'm going to attempt to make some speaker wire out of 28 AWG silver wire. I have a little over 1,000 feet of bare silver and 1000 feet of ptfe tubing (24 AWG). I'm planning to use 30 8ft wires per run. I could divide the conductors into groups of ten and then do a simple three-way braid with those. Any advice would be appreciated.
The ultimate goal is 8ft cables (give or take).
Remember that cable length is the bigger part of the equation. Not much difference between short 13/14AWG silver cables and long 12AWG copper cables.
c-J - I believe you've read enirely too much into the phrasing "ultimate goal". The "ultimate goal" is just the length of cable I need. I could have said the end result or desired length. I also could have said "the ultimate goal of this project is to create a set of 8ft cables". I was responding to this from Speedskater:I was only stating the length of cables that I planned to make to get Speedskater's opinion on length vs AWG.
If I could make it work, I'd be making shorter cables, but I've got some placement constraints where 8ft is about right. I can almost get 2 meter cables to fit, but I like some slack for safety/versatility purposes.
OK, whether wise or not, I've decided to add some more wire to the project. I'll end up somewhere between 10-12 AWG. I'm not quite sure yet. I'm going to acquire a full extra 1000 ft, but I may set some aside for interconnects rather than use all of it. The final determination may come down to whether or not it will remain flexible enough at larger gauges. I'm going to be making test runs with some bulk magnet wire I have.
