bda1 not locking properly on 192khz
0 Members and 1 Guest are viewing this topic. Read 1391 times.
project1971
« on: 8 Mar 2012, 07:15 am »
 good morning
i have problem with hiface evo and 24 /192 files.
my pc win7 x64  ultimate -hiface evo -bryston bda1 dac.
i play with jriver and wasapi event style , tried 100 mlsecs and 250 milsecs buffer ,i have 8 gb ram memory and usb data goes to hiface so green led is constant on.
  still when i play  24/192 files  the sound makes small instant stops and leds on dac go on-off like it's not locking on sample rate properly.
it does that only with 192 samplerate ,and with both spdif and aes/ebu cables from belden (1694a - 1800f )
strangely i used one dnm xlr and dac locked stable although it's not aes/ebu but only xlr ic !!!!
   do you have any idea about and a solution?
thanks
regards from creta
  • The Demo is Everything!
    • http://www.bryston.com
Re: bda1 not locking properly on 192khz
« Reply #1 on: 8 Mar 2012, 11:07 am »
good morning
thanks
regards from creta
Hi project
I can guarantee you it is not the BDA - if it was it would not lock on even the lower bit rates. One of the things I found when I was developing the BDP digital player was how much difficulty some of the other operating systems and sound cards had with the higher bit rates :duh:
James
project1971
« Reply #2 on: 8 Mar 2012, 12:09 pm »
dear james
   i know that it's not bda1 fault because as you see i am telling that i puted one dnm ribbon xlr ic and 192 rate locked stable .
i am wondering if it's jitter problem of the usb cable from pc to hiface (1.8m long )
maybe i should try shorter one ??
« Reply #3 on: 8 Mar 2012, 12:16 pm »
dear james
Gee I can not see the mentioned cable length affecting the signal quality to that level but I guess it is worth a try.
james
alexone
« Reply #4 on: 8 Mar 2012, 03:06 pm »
aaaaarrrghhh...wrong here :roll:
al.
