0 Members and 1 Guest are viewing this topic. Read 8168 times.
Just checked with Tach @45 when 33.3 accurate: I get 45.6 rpm. That's a bummer! Half a revolution per 45. Is there a threshold over where you really start noticing it?
Ah, got it. Also, what are you folks using for a strobe light? I'm trying to find something on Google, but nothing has turned up yet.
Off topic, but the square motor is an AC motor where the speed is fixed by the main's frequency. I found that moving the square motor further in or further out to adjust tension on the belt has some minor influence on the speed, and sometimes replacing the belt can change it too. If the speed is way off, check for pulley slippage. I'm now running an Origin Live DC motor kit on my Classic which is very good once sorted.
