0 Members and 1 Guest are viewing this topic. Read 9027 times.
If you don't have to go integrated, I'd suggest Dusty at Channel Islands D500mk II mono blocks. I had excellent luck driving 1.6, 1.7, 3.7 and 20.1 with these amps.Ive also had great luck with the Luxman L-590A II, the Burmester 032, the McIntosh MC7000, the SimAudio 600i, 700i and i-7.
Care to compare the Channel Islands to Pass?
PatKeeping with your original request of an integrated, I used a Valve Audio Predator for several years first with my 1.6s and then with 3.6s.http://www.valveaudio.co.za/pdf/review_toneaudio_predator.pdf6922 preamp section so you can tube roll to your hearts content.
that Audio Predator looks very nice...4k plus to get to my location all in i would have to add another 1/2k..... so that's big budget.... That 225 Anthem is only 1600 bucks.... Big difference !! Not sure which way to go,, i do like quality to be sure..... Not too many used integrated amps for sale that are good quality.... seems you get Hi and Low,,not much mid field..
