Audiophilleo 2?
0 Members and 1 Guest are viewing this topic. Read 4356 times.
bluesea
Audiophilleo 2?
« on: 2 Mar 2012, 09:33 pm »
Hi Paul,
Do you currently have a PS compatible with the Audiophilleo 2? Cost?
Paul Hynes
    • http://www.paulhynesdesign.com
Re: Audiophilleo 2?
« Reply #1 on: 3 Mar 2012, 12:39 pm »
bluesea,
It would appear that the Audiophilleo 2 takes it’s power from USB and regenerates a new supply from this via a galvanically isolated arrangement.
I have not inspected an Audiophilleo 2 so cannot comment on what would be required internally to patch an external supply into it and upgrade any on-board regulation.
Regards
Paul
slippers-on
Re: Audiophilleo 2?
« Reply #2 on: 9 Mar 2012, 06:51 pm »
Mr.Paul Hynes...I am interested in ordering one of your power supplies for my Simaudio Moon 110LP. How would I go about doing that? I went to your web site and sent you an email. I live in the States. How much would that supply cost me?
bluesea
Re: PS for Wavelength Wavelink HS
« Reply #3 on: 30 Apr 2012, 07:38 pm »
Hi Paul,
I ended up getting the Wavelink HS instead of the Audiophilleo 2.
Have you considered a USB connected external power supply for the Wavelink HS?
Any thoughts on the efficacy of a PS for such an application? I'm guessing your SR1 would be the base unit?
