Digital amplifier technlogy questions. . .
0 Members and 1 Guest are viewing this topic. Read 1407 times.
pjchappy
« on: 14 May 2004, 03:36 am »
Are there any 'high-end' amps that, like the Panny XR series, take a DIGITAL signal in and keep it digital (PWM) into the speakers?
I see a lot of new digital amps, but they take an analog in.  I was just wondering if there were any amps like described above so as to skip the A/D section. . .
p
vpolineni
« Reply #1 on: 14 May 2004, 03:41 am »
Tact audio uses the same technology as the panasonic amps... they were first to do so.
dwk
« Reply #2 on: 14 May 2004, 02:28 pm »
As far as I know, the TI Equibit technology used by Panny and Tact is the only 'direct digital' approach for PCM audio (ie normal CD or DVD). The other approaches such as the Tripath and IcePower all are really variations on conventional analog technology that require analog signals for feedback, and so the idea of 'direct digital' interfaces doesn't make any sense. Tripath is supposedly going to offer a direct digital interface to their chips, but AFAICT this will just integrate a D/A onboard, which helps with cost but not necessarily quality.
The Sony DSD amps are somewhat different in that there is also no conversion, but the DSD signal is already effectively a pulse modulation. Conversion from PCM to DSD is pretty much exactly what bitstream D/A converters do, so you are still faced with a form of conversion in this case.
All in all, though, 'staying digital' is merely an implementation detail - you shouldn't really evaluate a particular amp by whether there is or isn't a conventional D/A stage present. As has been pointed out - it's all analog when it gets to the speakers, so there is ALWAYS a D/A conversion of some form happening. Don't get TOO hung-up on where it occurs.
pjchappy
« Reply #3 on: 16 May 2004, 07:12 am »
Ok, I'm still confused on exactly what PWM is and its conversion vs. typical PCM conversion. . . .
p
