0 Members and 1 Guest are viewing this topic. Read 14503 times.
Skeptical about conditioners. With new ac powered amps I'm gonna go the balanced isolation transformer route and call it a day.
Felix!
Good thing it's working for you! But you'll get half the people saying brand x conditioner is great and the other half saying brand x ruined the party. Bpt's make sense to me, and it's what people here I respect use.
You're speaking Chinese to me now... I don't know anything about this stuff, and I likely never would have looked into it except for what my "friend" did to me today. The difference in sound was very significant for me, and very much for the better. All I know is I'd like to have a conditioner of my own.
Keep in mind all "Power Conditioners" are not the same.You generally have these types of conditioning functions:Balanced Conditioning = Using a large transformer and running current in opposing directions to negate (balance) any issuesFiltration = various filtration devises to "filter" out sonic impuritiesCurrent Regulation/Stabilization = monitors current and maintains a stable levelMagic Beads and materials = some special (claimed) type of substance or substances that make the power more sonically pure. (again claimed)There are likely other devices and some also combine the above devices.So in looking for a Power Conditioner it is good to either listen and know which one works for you (as you did) and or know which type of Power Conditioning you might benefit from the most.
The conditioner is a PS Audio Quintet Power Center
see?
that conditioners are a mixed bag. Would you wanna try one after reading that?
Well, IME I'd consider the APC units high quality surge protectors that can regulate voltage. Not a huge improvement for me either. For improvements in sound, check Shunyata, Running Springs or PI Audio. All of those made a solid improvement in my system.And as I said above, different units will differ in ways that are system and power quality dependent. It is also commonly recommended to not put amps into conditioners due to dynamics being impacted. I recommend trying both ways
