Need help finding particular enclosure type for Felicia
0 Members and 1 Guest are viewing this topic. Read 1120 times.
tonyptony
I'm looking to build a 4 outlet (two duplex AC receptacle) Felicia. The problem is that I need a "power strip" type enclosure as I need to place it in a fairly narrow area. Has anyone ever seen a strip type enclosure which can directly accept standard outlets? And has enough height to house the parts for a Felicia?
poseidonsvoice
    • 2 channel/7 channel setup
tonyptony
Re: Need help finding particular enclosure type for Felicia
« Reply #2 on: 2 Mar 2012, 02:37 am »
Thanks. I did look there but couldn't find quite the right thing. The two duplex, 4 outlet jobs are all square. Most of the strip models (6 outlets or more) are designed to accept actual wall plate sized covers, making them much wider than I was hoping for. The only model that comes close (PB-BR06G) is a 6 outlet job, which I guess I could work with, but the gold plating takes it out of the running. An unwanted and unnecessary expense.
VH Audio sells a 6 outlet Oyaide, but that thing is $300! :o
