Brimar 6060 Yellow T's and Telefunken ECC801S 12at7 tubes
0 Members and 1 Guest are viewing this topic. Read 10879 times.
Heckler75
has anyone compared these (2) 12at7 tubes, Brimar 6060 Yellow T's  and  Telefunken ECC801S
my intergrated tube amp came with the (2) stock tubes(sovtek)    and wanted to upgrade them a quality vintage tube.
can the Brimar 6060 yellow t's- still be found?
ltr317
Re: Brimar 6060 Yellow T's and Telefunken ECC801S 12at7 tubes
« Reply #1 on: 28 Feb 2012, 04:04 am »
The Teles are fairly neutral sounding with excellent detail, and the Brimar Yellow Ts are some of the warmest 12AT7s, with very good presence ever manufactured.  Both types are expensive if they are tested correctly.  I sold some Brimar Yellow and the later White Ts here on AC a while back.  I still have a pair of both the Yellow and White Ts which I'm keeping until I get some more for a reasonable cost.
Heckler75
« Reply #2 on: 28 Feb 2012, 04:13 am »
thanks  for the info,  so the Brimar Yellow's   do have a  warmer sound.
how would you rate, the bass/midrange/ highs  and also soundstage?   for both
ltr317
« Reply #3 on: 28 Feb 2012, 05:08 am »
Since the Teles have more neutrality and detail, the bass and highs are probably better for the majority of listeners.  The Brimars have a beautiful midrange and a fuller sound.  Depends on the type of sound you like to choose one over the other.
tonyptony
« Reply #4 on: 29 Feb 2012, 01:00 am »
ltr317, do you have any idea how the GEC A2900 sounds compared to these? I've heard the TFKs and the Brimers (and agree with your descriptions), but have never heard the GECs.
ltr317
« Reply #5 on: 29 Feb 2012, 05:59 am »
No.  I've been trying to get some A2900s for years at a reasonable cost with no success.  They are even rarer than the Yellow Ts.
mark funk
« Reply #6 on: 29 Feb 2012, 11:04 am »
   Brimer? Try some of these,
http://www.tubemonger.com/12AT7_ECC81_E81CC_ECC801S_6201_6060_CV455_CV4024_CV4033_13D_s/8.htm?searching=Y&sort=9&cat=8&show=10&page=1
 I like Telefunken better then Brimer.
        :smoke:
Bill O'Connell
  • Retired . Music Lover
« Reply #7 on: 29 Feb 2012, 03:20 pm »
One other choice for you to consider is the Mullard 6201 gold-pin. :thumb:
shooter
« Reply #8 on: 29 Feb 2012, 06:13 pm »
On the Berning ZH270 the Brimar was preferred over the Telefunken ECC801s.
In a friend's VTL750, the Mullard was preferred over the GEC A2900.
