Passive Pre's NEW enclosure!
0 Members and 1 Guest are viewing this topic. Read 3656 times.
Niteshade
    • Niteshade Audio
« on: 21 Feb 2012, 10:21 pm »
New enclosure:
Photo of original:
The original passive was made in an aluminum enclosure. The new one is taller, thicker and thus much heavier. They are also the same height as our amplifiers.
gooberdude
Re: Passive Pre's NEW enclosure!
« Reply #1 on: 21 Feb 2012, 11:31 pm »
Looks good.
Have you come up with a way to hide the bottom panel with the new design?
Niteshade
    • Niteshade Audio
« Reply #2 on: 22 Feb 2012, 12:15 pm »
The bottom panel is still the same. I could try painting it. What I do not like: Paint on edges is extremely easy to nick. We'll try painting the bottom cover with these new passives.
Niteshade
    • Niteshade Audio
« Reply #3 on: 9 Mar 2012, 09:27 pm »
Passive preamp with HT bypass & two inputs.
Charles Xavier
« Reply #4 on: 9 Mar 2012, 09:51 pm »
Is the pricing the same ?
Niteshade
    • Niteshade Audio
« Reply #5 on: 9 Mar 2012, 10:44 pm »
The prices have not changed:
1) Passive w/ one input: $75.00
2) Passive w/ two inputs: $100.00
3) Passive w/ two inputs & HT Bypass: $175.00
These passives present an easy load to sources and therefore will not adversely tweak the sound as some passives do. They're as transparent as it gets.
roymail
  • Roy in TX
« Reply #6 on: 28 Mar 2012, 12:14 pm »
Traditional pot in-out-gnd design, or does it use a quality resistor on each side and shunt to ground?
I'm guessing you could do different colors, too?
Niteshade
    • Niteshade Audio
« Reply #7 on: 28 Mar 2012, 10:07 pm »
It is a carbon pot setup and does not use a shunt to ground circuit, however it does use star grounding. It's set up so that the input impedance stays relatively the same throughout the control's range and works extremely well with any source or amp combination.
They can be made in custom colors for a small additional fee when ordered alone. Presently I have black or dark red for no additional cost.
6L6PPP
« Reply #8 on: 10 May 2012, 11:37 pm »
These are really good sounding passives. I have the original design one input/ one output in a matching color for my blue Classic build NS-30 .... and a couple black ones I use with a red NS-30 and a wood trim LM3886 based power amp.
