0 Members and 1 Guest are viewing this topic. Read 67650 times.
I've seen this done before but I'm not sure I understand the concept, sonically speaking. Can you explain briefly and/or point me in the direction of an online resource?
Thanks Paul! I'm planning on doing wood filler, oil based primer, then Sherwin's line of SureChem raven black. With lots of sanding in between coats, I hope I can get that piano black finish. On the back of the baffle and the base I'm going to cover with Quiet Kote sound dampening spray. I'm not sure of that will make much difference, but it can't hurt you know?
Once I jumped into the bamboo, the added stiffness of that material really made a significant different in the rigidity of the baffle
Are you still set on the Alpha 15s?
Why haven't you considered making your main baffle sand filled?That mid layer in your sandwich could easily be replaced by a sand filled cavity.That tall and narrow baffle is gonna vibrate quite bad.
I have no idea what sand filling is. Just using the best methods I know.
