Drilling holes for GK-1R
0 Members and 1 Guest are viewing this topic. Read 2050 times.
PT914
« on: 11 May 2004, 06:09 pm »
I'm presently building the case for the GK-1R and using sheet metal.  Was drilling holes for the DCpcb, using a regular drill bit and the holes were not round or lined up perfectly.  Started to do some filing and using a die grinder, then I came across a unibit.  This unibit is great.  You can enlarge an exsisting hole and move it's center.  Makes round holes and bevels the edge nicely.  Manufacter is Irwin I think.  Great product.  Now if I can find a nice square hole maker.
Philip
AKSA
« Reply #1 on: 11 May 2004, 11:08 pm »
Thanks Philip,
Great advice!  Now, to see if I can buy these things Downunder........ :cry:
One thing is certainly true;  if you can build an AKSA in regional Australia, with our restricted tooling choices, it should be no problem in Juneau, Alaska!!
Hugh
Carlman
« Reply #2 on: 11 May 2004, 11:48 pm »
Quote from: AKSA
Thanks Philip,
Hugh
I bought a unibit from Grizzly.com when I bought my press.  I haven't actually used it yet but I look forward to it.  Irwin makes good tools.  They're sold at every Home Depot in the U.S.  (and probably Lowes)  If it's a 'hot commodity' I'll buy a slew of 'em and ship 'em to Hugh.
-C
some young guy
« Reply #3 on: 12 May 2004, 12:22 am »
here you go:
http://www.mytoolstore.com/delta/drpraccs.html
EchiDna
« Reply #4 on: 12 May 2004, 02:07 pm »
Quote from: AKSA
Thanks Philip,
you can get em all over the place Hugh... called a stepdrill in the metricated world  :mrgreen:
For some reason "alltools" in South Melbourne rings a bell - not too bad after 8 years away from home eh?
Seano
« Reply #5 on: 13 May 2004, 02:24 am »
They look like this....
As Echidna says.........they are available everywhere.  Even in a backwater country like Oz.
fos
« Reply #6 on: 28 May 2004, 02:16 am »
g'day
i was having the same issues with the holes when i came across a tool called a chassis punch. it uses a round die, a cutter nut and a bolt to tighten both pieces together.
i used the tool on 1.7mm aluminium, the only problem was the tool cracked the paint in the around the hole edges so the panels require repainting.
the punch in the photo is 1/2" and cost around $33aud, size was ok for the rca plugs and the front panel push buttons.
