Icon Amp
0 Members and 1 Guest are viewing this topic. Read 2037 times.
Efjay
Icon Amp
« on: 13 Feb 2012, 04:42 pm »
I'm considering the purchase of an Icon Amp http://www.nuforce.com/hp/products/iconamp/index.php for my desktop system. I do have two questions I hope someone has the answers to:
1. Does the current incarnation of the Icon cause speaker 'pop' when the unit is turned on? I intend to use 8ohm/90db sensitivity speakers.
2. Will I be able to hook the amp up to my subwoofer via the high level inout then out to my speakers via the high level output?
Thanks in advance.
Efjay
Re: Icon Amp
« Reply #1 on: 14 Feb 2012, 04:10 pm »
Regarding the second question, I have been informed by NuForce that a subwoofer cannot be connected in this manner.
Chromisdesigns
  • Darla, our beach cat, contemplating the sea
    • Fine-gemstones.com
Re: Icon Amp
« Reply #2 on: 19 Feb 2012, 01:26 am »
Thanks in advance.
Would it work?  Probably yes, if you have an active subwoofer that can be connected to speaker-level outputs, and then connect your speakers to the woofer high-pass outputs.  I don't see how the ICON amp would even know the sub is there.
Now, the "original" ICON is a different beast, because it has internal equalization to match the S-1 speaker response curve.  But that's not the one in your link.
But  in any case, it's probably better to drive the subwoofer with line-level outputs from the source component, using a splitter, if necessary.  With a passive sub, of course, you would also need a power amp for the sub.
