Pro-Ject HeadBox II SE (Black) - $350 or trade for DAC - Texas / DFW / 75019
0 Members and 1 Guest are viewing this topic. Read 704 times.
doctor_worm
Only a few hours on it, still have original packaging, asking $350.00 (I'll cover shipping), was $400 new.  I just recently became unemployed so I will be a bit short on funds to finish putting together my 2 channel system.  Need the $$ for a DAC instead.
Supports 2 headphones with seperate volume controls.
[From http://www.sumikoaudio.net/project/products/headbox_se2.htm]
The Pro-Ject Head Box SE II provides a cost effective solution for headphone listeners whose electronics are without headphone jacks. The Head Box allows connection of two sets of headphones each with its own volume control.
TECHNICAL SPECIFICATIONS
Power Output 7000mW / 30 ohms, 110mW / 300 ohms
Headphone Connection >30 ohms
Signal-to-Noise Ratio 110dB ref. full output (115dB-A weighted)
Frequency Response 30Hz-20kHz, -0.03dB
THD (IMD) 0.003%/30 ohms / (0.007%/300 ohms)
Gain 12dB
Headphone Jack 3-pole, 1/4 in. x 2
Power Consumption 16V/230mV AC
Dimensions (WHD) 4.1”w x 2.9”h x 6”d in.
Weight 2.4 lbs.
Finish Black
