Tang Band/ H-frame Alpha tweaks
0 Members and 1 Guest are viewing this topic. Read 3779 times.
Poultrygeist
« on: 10 Feb 2012, 03:57 pm »
I glued cork to the rear baffles ( cheapo Ikea placemats ) to reduce resonance and reversed the modded super horn tweeters so they fire to the rear ( as others suggested and they were right! ). Still no correction on the TB's which sound pretty dang good to my aging ears. They're driven by Bottlehead 2a3 Paramours while the Alpha's are powered by two Dayton APA 150's with built in crossover controls.
Ric Schultz
Re: Tang Band/ H-frame Alpha tweaks
« Reply #1 on: 10 Feb 2012, 10:09 pm »
Do you want bass that is way tighter, cleaner, fuller, more dynamic and more pure?  If so, then you need to damp the frame of the Alpha with EAR SD40AL and magnet brace the woofer.  You get 13 ply birch plywood and make the brace out of two thicknesses (1.5 inch thick) and at least 2 or three inches the other direction.  You epoxy a piece of the same plywood onto the magnet of the woofer but make sure it overlaps on the bottom and top a bit so you can drill some holes there as you are going to bolt this epoxied plywood to the brace.  This way, you can always remove the woofer if you blow one.  Total crazies can just epoxy the brace right to the magnets.  This brace would be bolted to the magnet and then epoxied and screwed to the top and bottom of the inside of the H-frame.  Look out world, here comes bass!
Do you want way more midrange transparency and purity and speed.  Well, do the same as you did for the woofer but to the Tangband.  Attach the brace to the back of the magnet the same way, curve it around so it attaches to the baffle above the tangband and also attach it to the base.  Wowie Zowie....mindblowing sound.
Of course you want to get rid of your binding posts.....they suck big time...as well as any connectors on your speaker wires.  Simply solder your speaker wires directly to the drivers with no other wire in between.  Please solder directly on the eyelet to the wire coming from the voice coil and not to the other end of the solder tab.  You will not burn the voice coil as long as you do it with a hot iron and fast.  You can heatsink the lead out wires to the coil if you are a timid type.
But maybe you like the sound of resonating woofer frames, resonating woofer and midrange magnets, thin resonating midrange baffles and veiling connectors.  I don't.  For a couple hundred $s you are in a whole nuther league of goose bump city!
Poultrygeist
« Reply #2 on: 10 Feb 2012, 11:07 pm »
Rick, mama don't allow no ugly speaker's round here.  :D
Ric Schultz
« Reply #3 on: 11 Feb 2012, 02:55 am »
come on! you think your speakers are pretty?  I guess that is the ugliest she can handle, eh?  I was thinking of making some H frame speakers to sell but I realized they would be far too ugly for most people.  Please get your own room so you can tweak your speakers.......you will never come out!......she will have to drag you.  You will be in heaven!  Of course, you could put a bed in the room and when she hears the beautiful sounds coming into her being she will immediately want to make love to you.  You see, its for her too!
