0 Members and 1 Guest are viewing this topic. Read 5035 times.
So, you've set the stylus in the groove? With the platter spinning and also not spinning? Have you tried setting the stylus in the groove, but with the deck (turntable) unplugged from the wall outlet?
What arm? Same arm in all of the iterations? If so, check the continuity of the tonearm wiring. Check each lead to ground to see if there is a short to ground. If the arm has a removable headshell check continuity of each contact/lead. Your description indicates a wiring issue only when the arm lead circuits are energized by signal.
You need to isolate the cause of the vibration with the use of damping techniques. The offender is too coupled to the chain.
Perhaps I'd try some cork under the motor assembly and see if that reduces the hum.Wayner
Yeah, I have tried that with the exception of unplugging. The tt motor has to be running to get the hum.
OK, so the source of the hum was mechanical from the motor.
Yeah, since I wasn't even thinking in terms of it being from a mechanical (or electromechanical) source, I was essentially on the wrong track. The table and motor assembly are on a 2" maple platform on isoblocks, which was receiving the vibration from the motor and causing it to resonate through the belt, platter and record in succession and be picked up by the stylus. What's interesting to me is that the hum was exactly 60 hz (I checked on a Strobotuner). I'm sure there's some law of physics that would explain why the vibration is the same frequency as a typical ground hum, but I guess I wasn't paying attention in class that day.
Transformers are known to hum. The old style core and coil ones were made from sheets of steel, welded or crimped together. Once in a while, these laminated sheets would come lose and start vibrating. Since the transformer is operating at 60 hz, the sheets of steel would start to vibrate at that exact frequency and mimic 60hz emf. So many people would be busy trying to rig up Faraday cages to stop the hum, when in fact it was all a mechanical noise. Shielding did nothing to stop it. Securing the laminates did.I think this problem happens lots of times when dealing with turntables. The bad news is, it's hard to determine if it's emf or mechanical by nature, and that is the first path to take...diagnosis. Then the cure comes.Wayner
That is why I like to use known cartridges that are EMF hum busters, then if you end up with a problem, you know that it is mechanical in nature.
The cure was, he added shielding over the motor. Following his advice I obtained some samples of Netic and Co-Netic sheet metal from Magnetic Shield Corp.
I wonder if the type of shielding tape that is meant to be used in electric guitar control cavities would work well for this purpose? It would be fairly manageable and could be easily cut to size.
