0 Members and 1 Guest are viewing this topic. Read 8712 times.
This is one of the great dilemmas of our age - how to set up a center channel speaker with a large flat screen TV.
I have my TV on a wide low shelf and I'm toying with the idea of adding a center channel:http://www.audiocircle.com/index.php?topic=95361.msg957838#msg957838I have no choice but to put the center speaker on top of the shelf, but then the question is what to do with the TV. I need to raise it up by a few inches. I could either add the optional TV stand that attaches to the cabinet, or a separate TV stand that sits on the cabinet behind the speaker or on the floor behind the cabinet. The speaker would be free of anything around it If you have yet to choose a shelf, why don't you consider one like this?
Personally, I'd wall mount the flat screen if I could. That leaves the top shelf of the rack wide open for the center channel.
I am currently considering television stands along the lines of http://www.tvstands.com/Home-Loft-Concept-Dynasty-60-TV-Stand-in-Black-XML2120-WLK1019.html or http://www.tvstands.com/Tier-One-Designs-60-TV-Stand-with-Wire-Management-in-Clear-T1D-130-TDD1009.html where I would put the center channel in an inside shelf where the shelf is (mostly) open. One negative of each of these particular stands are that neither is completely open in back, in the center of the back.
I agree. However stands with shelves able to handle the bigger beefier amplifiers or receivers should be able to handle my center channel speaker. Unfortunately, many shelves that can handle my center channel speaker are not (completely) open in back.Ideally, I'd like a television stand that's at least 60 inches in length, with a shelf that is open in back that is able to handle the size and weight of my Von Schweikert center channel speaker, where my speaker is horizontally centered within the television stand (not off to the right or the left of the center of the television stand).
This is an interesting possibility. Thanks for the links. I saw that the back panels can be raised or lowered. But is the furniture frame rigid and sturdy enough to hold a relatively heavy speaker in the top shelf as well as a large widescreen on top of it, with the back panels removed?Although not a requirement, it would be nice if the bottom shelf on whatever I got had a back to it, and the top shelf were open. This would hide any wiring clutter that's on the floor behind the television stand.
With Salamander, the frame and shelves are very sturdy. That's what you pay the bucks for. The side and back panels are thin and don't provide any support to the frame. I left the back panels off. If you want it partially covered I suppose you could cut the back panels to size if you're adept at that kind of thing.
Here is another alternative approach:http://www.blu-ray.com/community/gallery.php?member=Woodyhttp://www.soundanchors.com/page60.htmlor sfc22 or 18 http://www.sanus.com/us/en/products/speaker-foundations/sp-steelI have old vr4 gen II (driver/unit upgrade pending...) and ( earlier with lcr-31) now with lcr-35 center. Iḿ facing the same problem when upgraded from tube tv to 65" sony hx929. Earlier all gadgets fitted to one rack and TV on top and Center speaker on top of TV.
situation is challenging because the floor reflections also need to be avoided and center should not be positioned too low
One concern with putting the center channel below the thin widescreen is it is placed low. It may have to be placed so low that the sound it produces may bounce off the floor, and/or be blocked by anything low in the room that gets in its way.One possible solution might be a bracket on top of the widescreen. Here's one: http://www.centerstagebracket.com/3006.html
