BP-1.5 Phono Stage
0 Members and 1 Guest are viewing this topic. Read 2205 times.
ashtarul
BP-1.5 Phono Stage
« on: 6 Feb 2012, 06:01 pm »
James,
Are there any plans to refresh/update this model in the near future?
Ash
  • The Demo is Everything!
    • http://www.bryston.com
Re: BP-1.5 Phono Stage
« Reply #1 on: 6 Feb 2012, 06:54 pm »
James,
Ash
Hi Ash,
No plans - it is a Phono Stage which has evolved over many years and the level of accuracy (RIAA)  is exceptional.
james
« Last Edit: 6 Feb 2012, 07:56 pm by James Tanner »
alexone
« Reply #2 on: 6 Feb 2012, 07:42 pm »
James,
the BP1.5 has no xlr connectors. why?
al.
« Reply #3 on: 6 Feb 2012, 07:57 pm »
James,
al.
Hi al,
XLR balanced cables make sense over longer distances and most people would place the BP-1.5 close to their preamp.
james
SHV
« Reply #4 on: 6 Feb 2012, 10:24 pm »
Hi al,
james
That is interesting.  I had assumed that it was better to keep the cable length from the phono cartridge short and have the boosted signal coming from the phono amp to the pre-amp be the longer distance.  My TT is about 15' from the pre-amp.
Elizabeth
« Reply #5 on: 7 Feb 2012, 01:19 am »
15 feet is not a problem for phono box to preamp.. If you had it 50 ft... then balanced would be better...
And yes the cable from the TT to the phono prepreamp should be as short as practical. that  signal is really tiny.
One thing though, If you have the 1.5, then you either need the power supply just for the 1.5, or you have a really long cord for the 1.5 from the power supply with your BP 26?
I own an Audio Research PH-2 besides the Bryston 1.5 and BP-26.
The ARC  PH-2 is a fully balanced in and all the way through and out. Not very many phono boxes are.
SHV
« Reply #6 on: 7 Feb 2012, 01:31 am »
ashtarul
« Reply #7 on: 12 Feb 2012, 07:45 am »
Any idea what the retail price is in Canada and the US for this amp?
Ash
