SOLD McIntosh MC240 Sale/trade/partial trade $2200
0 Members and 1 Guest are viewing this topic. Read 4790 times.
jvia
McIntosh MC 240 in excellent working order and I think very good physical condition, pictures are large should tell most of the story. Chassis is about as good and clean as I have seen given age, lettering for output tubes still decent,  lettering around pre amp tubes virtually gone. paint overall good and you can see underneath in pics. This is a take it out of the box plug it in and play unit. Will be incredibly well packed for shipping and I will ship anywhere in the world just ask. Will consider trades, especially for preamp with phono, partial trades for things I haven't had etc etc etc Questions, call 615 260 9569 or write Specs below taken from Roger Russell's always wonderful site, audio philes everywhere owe you Roger, thanks. ,: 40w40w/ch stereo, 80w mono. Response 16-40kHz (+0 -0.1dB). Distortion 0.5%. Noise & hum -90dB. Output impedance 4, 8, 16, 125 and 600 ohms. 600 ohm center tap internally grounded. (2, 4, 8, 16 and 32 ohms in mono). Output voltages 25 (isolated), 70.7 (one side grounded) and 140V (center tap grounded). Internal impedance less than 10% of rated impedance. Input impedance 250k. Input sensitivity: 0.5V (in mono or twin amp). 2.0V in stereo. /ch stereo, 80w mono. Response 16-40kHz (+0 -0.1dB). Distortion 0.5%. Noise & hum -90dB. Output impedance 4, 8, 16, 125 and 600 ohms. 600 ohm center tap intenally grounded. (2, 4, 8, 16 and 32 ohms in mono). Output voltages 25 (isolated), 70.7 (one side grounded) and 140V (center tap grounded). Internal impedance less than 10% of rated impedance. Input impedance 250k. Input sensitivity: 0.5V (in mono or twin amp). 2.0V in chrome chassis. Line output octal socket for higher impedances and voltages. Barrier strips for 4, 8 and 16 ohms. Audio inputs: stereo, twin and mono. Gain controls: twin p, balance and mono. Input switch: stereo, twin amp or mono. Can be used for 80w mono. Line voltage switch: 117 o 4-6L6GC/7027A output, 3-12AX7, 2-12AU7, 2-12BH7 Solid state rectifier. Size 8"H, 10-3/4"W and 17-1/4"D. Weight 56 lb. Sold from 1960-1969. Last retail price $288.00
« Last Edit: 26 Feb 2012, 01:46 pm by jvia »
beeah
Re: McIntosh MC240 Sale/trade/partial trade $2200
« Reply #1 on: 6 Feb 2012, 04:50 pm »
Asking price?
Whitese
« Reply #2 on: 6 Feb 2012, 04:51 pm »
Its there on the title...
beeah
« Reply #3 on: 6 Feb 2012, 05:10 pm »
I'm pretty sure it wasn't there before - nor were the pictures when I first looked...
hatrack71
  • beyond help..
« Reply #4 on: 26 Feb 2012, 01:38 pm »
What trades would you consider? I have the following:
Conrad Johnson PV-2
Bottlehead Foreplay
Precision Fidelity M-8
Precision Fidelity M-7
Precision Fidelity C-8
Fisher 500b, 800b, 400, and kx-200
Scott 340-b
Diyaudio St-35
Acoustician Sound Engineer compression drivers( large format Altec and JBL copies)
Thorens TD-150 AB and Thorens TD-150 II
NAD 533 with upgraded acrylic platter
....probably have a few other things too perhaps. Maybe there is something you like there, maybe not. Wanted to try none the less.
