Cornet II metalworking questions?
0 Members and 1 Guest are viewing this topic. Read 2033 times.
EZ_Angus
    • http://faculty-staff.ou.edu/G/Kevin.B.Grier-1/
« on: 5 Feb 2012, 05:49 pm »
Thinking of getting a Cornet II kit but I absolutely do not want to do any metalwork. Has anyone here ordered the plates from Front Panel Express?
galyons
Re: Cornet II metalworking questions?
« Reply #1 on: 5 Feb 2012, 09:11 pm »
I have ordered front and back panels from them.  Top notch folks.  Excellent work!  The design software is pretty easy to use.
Geary
bregez
« Reply #2 on: 5 Feb 2012, 10:16 pm »
If you use the Lansing enclosure you will have to do metal work on the front and rear panel of the chassis.  The front and rear have a complex cross section (extrusions) that I am positive FPE does not stock.  You cannot replace these panels with flat panels!!  The top panel can easily be done by FPE.
poty
« Reply #3 on: 6 Feb 2012, 08:10 am »
As obvious option - Lansing has personalisation service (expensive!).
I'd go different way - use full-wide enclosure with customisations from one of the services (FPE, ModuShop) and isolate the transformer with all AC connections in shielded zone.
