No sound from New Rythmik Sub - puzzled
0 Members and 1 Guest are viewing this topic. Read 2172 times.
jackmonkeyhat
« on: 4 Feb 2012, 07:11 am »
Evening chaps,
So I got my new rythmik sub today turned it on and no sound - I'm sure I must be doing something basic incorrectly. Any ideas?
Steps so far -
RCA outs from wyred 4 sound Dac-2 to Line In (XLRS still connected to amp)
Power on (Green light)
AVR 12 set in low pass filter slope setting.
jackmonkeyhat
Re: No sound from New Rythmik Sub - puzzled
« Reply #1 on: 4 Feb 2012, 07:33 am »
Update we have sound! Just needed to change my crossover right up initially.
Any suggested settings to pair nicely with the Sound Towers folks?
jsalk
« Reply #2 on: 4 Feb 2012, 02:37 pm »
Here is a quick way to get a fairly good rough set-up.
Start with the PEQ gain set to minimum (off).  Set the crossover frequency to about 120 - 150hz.  Set the gain slightly higher than normal.  Play some music with deep bass and, while sitting in the listening position, have someone adjust the crossover phase until you hear the highest level of output from the sub.  The goal here is to get the phase set correctly.  The sub will sound the loudest when there is a minimum of out-of-phase cancellation in the overlapping frequency range.  The phase setting should now be set roughly correctly.
Then set the crossover frequency to about 50hz (to cross with the SongTowers) and, while music is playing, turn the gain down very slowly until the sub stops calling attention to itself.  Once you have the gain set properly, you should not notice the sub except for the fact that your system now plays quite a bit deeper than before.  If you notice the sub, the gain is probably set too high.
While this is not a very sophisticated setup procedure, it should get you in the ballpark in fairly short order.
Establishing more precise settings and using the PEQ function appropriately will require measurements.  THUB and Nuance have posted quite a bit on this topic and you can search for their explanations.
I hope this helps.
- Jim
jackmonkeyhat
« Reply #3 on: 4 Feb 2012, 05:45 pm »
Thanks Jim!
« Reply #4 on: 4 Feb 2012, 06:43 pm »
Hey jack, so still improving on the system I see. Been doing any DJin' ?  Hope all is well uptown, and the neighbors are upstairs rather than down with the new sub. Be well buddy.  :thumb:
jackmonkeyhat
« Reply #5 on: 5 Feb 2012, 05:04 am »
Hi Arthur!
Long time no hear,
No time for DJ-ing these days sadly due to work, so I'm using the PC as the front end for my music. The song towers are sounding better and better as I work on other parts of the chain. Thanks again for letting me hear them  :D
