0 Members and 1 Guest are viewing this topic. Read 36984 times.
Clayton, do you have waterfall plots that yiu can share? The steady state plots don't really show that the unit acts as an absorber.
+1.Anand.
What do I think? Well, if you look at the waterfall plots at the 43 Hz resonance, it's fairly clear that the "Black Hole" reduces decay time at low frequencies quite dramatically. The reduction in decay time is apparent down to 20 Hz, and it seems to be effective up to maybe 100 Hz, although to a lesser extent.
It looks to me that there's a frequency below which active absorption becomes more effective than passive absorption.
The only other system improvement I would positively recommend is ditching all conditioners/filters etc. and going over to balanced power using a minimum 4kV transformer to plug all equipment into, eliminates restriction in dynamics that virtually all other devices other than balanced power
I'm based in the UK
What do I think? Well, if you look at the waterfall plots at the 43 Hz resonance, it's fairly clear that the "Black Hole" reduces decay time at low frequencies quite dramatically. The reduction in decay time is apparent down to 20 Hz, and it seems to be effective up to maybe 100 Hz, although to a lesser extent. It looks to me that there's a frequency below which active absorption becomes more effective than passive absorption.
You're disagreeing with his interpretation of the graphs why? How many traps do you think it would take to match that performance, and how much would it cost?
