How do you know if a tube is microphonic?
0 Members and 1 Guest are viewing this topic. Read 3071 times.
pjnad
« on: 2 Feb 2012, 02:30 am »
I'm kind of a newbie to tube equipment having acquired my fist piece ( Modwright SWL 9.0 Signature pre ) lat year.
I've been enjoying it and doing some tube rolling. I just swapped in a pair of tung sol 5687s that I have...when I touch the volume knob or even the rack I can hear it through the speakers. This had been happening with another pair of tubes as well. I had picked up a pair of jtl tung sols recently and after installing them, no noise. When I swapped them out tonight the noise is back. The tubes sound great though and nothing is coming through the system while it's playing.
Originally I thought it was a ground or connection issue but I just remembered reading something about microphonic tubes.
Also, is there any issue other than the noise to be concerned about...
Any help is appreciated.
JoshK
Re: How do you know if a tube is microphonic?
« Reply #1 on: 2 Feb 2012, 02:38 am »
talk into the tube with the volume up a bit, do you or your friends hear your voice?  Can you tap the tube and hear a ring or a buzz ring through the speakers...you have a microphonic tube.   Its a pretty annoying thing to hear when you hear it.
SET Man
« Reply #2 on: 2 Feb 2012, 02:51 am »
Hey!
   Even the best measured tube will make a pinging noise is you tap directly on the tube. But a good one should stop ringing quickly  :D
   In your case hearing ringing from the rack is not a good thing. That mean it pick up vibration from the rack too. But if the tube sound good to you and no noise than maybe a good isolation feet or platform will help.
    A cheap way to do it to use a piece of dense wood or granite sheet with lightly inflated bicycle tire inner tube under it.... actually this is what I use with my system, with my amps, preamp , turntable and CD player. :D
Take care,
Buddy :thumb:
Levi
« Reply #3 on: 2 Feb 2012, 02:53 am »
+1
Noisy tubes surely are annoying.
pjnad
« Reply #4 on: 2 Feb 2012, 03:03 am »
Okay. Thanks guys for the replies.
Interestingly enough now that the tubes have warmed up a bit I'm not getting any ringing from the pre or the rack...go figure  :scratch:
I am using some isolation pieces: the amp is on a granite slab with herbies iso cups which are great -definite sonic improvement when I added them. The dac ( which is fairly small - bel canto ) is on herbies tenderfeet. The pre and the cd/transport both sit on vibrapod cones/feet.
I am thinking of getting more of the iso-cups to replace the vibrapods as budget allows...but that might have to wait a bit as I'm planning on having a dedicated line and an audiophile outlet installed this month- but that is probably a topic for another thread  :roll:
SET Man
« Reply #5 on: 2 Feb 2012, 03:06 am »
Hey!
     Oh! It is normal for some tube to make noise and pinging sound when warming up. So, no worry there if they are quiet after warming up. Just enjoy them. :D
Take care,
Buddy :thumb:
JoshK
« Reply #6 on: 2 Feb 2012, 03:17 am »
yeah, warming up is not a fair judgement...it takes time for the plate, structure and cathode to get warmed up, expanded, etc.
pjnad
« Reply #7 on: 2 Feb 2012, 03:39 am »
Again, thanks. I know that the tubes need to warm up to sound their best...but, previously I did have a pair in that rang warme or cold...so, when I put these in and they rang, I thought , oh here we go again.
Anyway, they do sound good and they are pretty quiet re:tube rush etc.
I'm learning thanks to folks like you and that's always a good thing.
dB Cooper
« Reply #8 on: 2 Feb 2012, 05:54 am »
Another thing to consider is that microphonics can originate in other ways- some large "boutique" caps can exhibit much the same phenomena. Don't know if that pertains to your equipment or not.
Ericus Rex
« Reply #9 on: 2 Feb 2012, 12:36 pm »
If they don't ring and bother you when the music is playing then just enjoy them!  Changing a microphonic tube just cause it's microphonic isn't necessary if it isn't noticeable during playback.
T
« Reply #10 on: 2 Feb 2012, 11:10 pm »
Thanks guys.  I learned something today.  I never knew microphonic meant it could actually function like a microphone.  I have yet to try much tube rolling in my belles 21a preamp because I like my present sound.
