0 Members and 1 Guest are viewing this topic. Read 4595 times.
None, just contact Bryston
James, what would be the cost of a 19" 3BSST face plate in silver and 19" 7B SST silver?Steve
Why are you replacing them? If the silk-screening is coming off, Bryston may cover that under warranty. As always, Mike at Bryston is the guy to talk to for the final word on the subject.
hi, Steve!i believe that for example the older ST or even SST series can't have the newer c-series faceplates...?!? you should check with Bryston in any case al.
