Jamo MPA-101 Amplifier Stereo-Mono-Subwoofer Amp
0 Members and 1 Guest are viewing this topic. Read 4231 times.
silver_strings
« on: 1 Feb 2012, 04:29 am »
Hi for sale is a Jamo Mpa-101 amplifier, Its in excellent shape a solid 8/10, it can be used a stereo or subwoofer amp. Its really solidly built. The soun quality is very clear well defined with good precence at this price its hard to find a better amp.
114+ shipping in the US which will be 10-24 depending on your location. I accept Paypal. I can ship internationally contact me for to get shippping price
Design:
Design The MPA 101 is a compact, high-quality amplifier for multiple purposes. The amplifier can be set to operate in full range mode to power regular speakers or set in an adjustable low-pass mode to power passive subwoofers. The volume control is conveniently located on the front; the remaining controls are all placed on the back panel of the amplifier. Technology The MPA 101 features 2 x 50 Watts (4 Ohms) amplification, or 1 x 100 Watts (8 Ohms) bridged. It is supplied with line-in/line-out connections to enable daisy-chaining of multiple MPA 101s. The amplifier can be set to operate full range (20-20,000Hz), or set in an adjustable low-pass mode for powering passive subwoofers, such as the IW 1060 SW and the IW 860 SW in-wall subs.
The MPA 101 offers a variety of high-end features: Daisy chaining allows users to combine a number of amplifiers, if needed Signal sensing provides automatic on/off capability Protection circuitry prevents shorts and overheating The MPA 101 is a small, but capable amplifier that’s an excellent choice for 2-channel stereo or other uses. MPA-Sleeve The MPA-Sleeve is designed to hold up to 3 MPA amplifiers and comes with rack mounts and blank panels.
Technology:
Specifications:
System Type: Amplifier
Weight (kg/lb): 4.8/10.5
Product dimensions (mm/in, HxWxD): 140 x 145 x 324/5.5 x 5.8 x 12.8
Outputs: 2 x 50W (4Ohm) 1 x 100W (8 Ohm)
Finish: Black
« Last Edit: 9 Dec 2012, 12:14 am by silver_strings »
silver_strings
Re: Jamo MPA-101 Amplifier Stereo-Mono-Subwoofer Amp
« Reply #1 on: 19 Feb 2012, 10:14 am »
Bump
silver_strings
« Reply #2 on: 26 Feb 2012, 11:35 pm »
up^
silver_strings
« Reply #3 on: 28 Mar 2012, 04:17 am »
bump
silver_strings
« Reply #4 on: 11 Nov 2012, 05:36 am »
Price drop
silver_strings
« Reply #5 on: 28 Nov 2012, 08:46 am »
Bump
silver_strings
« Reply #6 on: 5 Dec 2012, 09:56 pm »
Price drop
silver_strings
« Reply #7 on: 9 Dec 2012, 12:14 am »
Bump
silver_strings
« Reply #8 on: 28 Dec 2012, 07:06 pm »
Up
tg3
« Reply #9 on: 31 Dec 2012, 04:00 pm »
How noisy is the fan?
silver_strings
« Reply #10 on: 20 Jan 2013, 09:13 pm »
It only turns on when its hot and its barely audible
