Supra EFF-i Balanced / XLR interconnect cables 1.2 Meter pair, Free Fed EX 48/.
0 Members and 1 Guest are viewing this topic. Read 1181 times.
undertow
Up for sale is one pair of 1.2 meter, or about 40" pair of Supra EFF-i BALANCED/ XLR with Supra official XLR connectors.
These replaced many pairs of Cardas Reference, and Golden cross cables in my system. I have one additional pair not being used at this time. These are the level just below the Sword which is about 5 times the cost, these are 95% of the performance.
They were about 210.00 terminated by supra.
I can let them go for 90.00 shipped and that will include paypal fees. See below
EFF-I: Our Multi Test Winner
A reinforcement of even the finest details is the goal of all cable design. A traditional cable can, however, not achieve that quality, due to the construction. A good interconnect must have low capacitance and low skin-effect.
The skin-effect has a dynamic and noticeable influence because an audio signal is nothing but variations of frequencies and sound levels.
If we were to transfer only one stable frequency the skin-effect would not be any problem. The frequencies push the signal differently far out from the centre of the conductor. High frequencies travel on the surface whereas low frequencies travel inside the conductor.
Thus, the higher the frequency, the higher the resistance.
In order to minimize the skin-effect the EFF-I is designed in accordance with Equalized Frequency Flow (EFF) Technique. It is based on tube shaped conductors with a wall thickness of 0.20mm, which is well below the smallest skin depth within the Audio range.
This allows the same resistance for all frequencies. The result is a transparent and exact reinforcement with clear room definition.
EFF-I One of SUPRA´s most awarded products, not without good reason...
