Cnsidering Panasonic PT-L500U projector...
0 Members and 1 Guest are viewing this topic. Read 1722 times.
ScottMayo
« on: 9 May 2004, 05:11 am »
Anyone have any experience with it? What sort of screen have you used with it?
gongos
« Reply #1 on: 9 May 2004, 05:56 am »
Buy it. I have 106" Da-Lite high contrast screen with mine. I tried a couple Mits. projectors before this one, but the 500U blew them away. I've had mine for 3 months and couldn't be any more pleased.
rotgg
« Reply #2 on: 13 May 2004, 12:51 am »
i have one and am also very happy i would buy another
ScottMayo
But...
« Reply #3 on: 25 Jun 2004, 01:35 pm »
It sounds like the bulb has to be replaced every 2000 hours - at $350 a pop. That's not exactly cheap...
cytocycle
« Reply #4 on: 3 Aug 2004, 02:54 am »
You won't find bulbs cheaper (on any projector) and only a handful of projectors will do 3000+ hours on a bulb, so this is quite normal.
I had to spend twice as much on a used Optoma H76 to significationly better the Panasonic new, and it does 3000 hours in Economy mode but the bulbs are more expensive.
If your worried about bulb life keep your CRT for daytime viewing and walking around the house(my ex-girlfirends favorite thing to do) and and use the projector for nights/movies/occasions.  I only put 700 hours on in 2 years on my last projector but now I've put 300 hours on three months (it much more enjoyable now that I have HDTV and DVD's and I don't have to mess with my HTPC.
2.75 hours a day 365 days a year for 2 years = 2000 hours. (my two prior rear projections broke down and cost more to repair in that same time frame)
